End of run add-on?
Old 07-01-12, 10:12 AM
End of run add-on?
I would like to add an outlet to a basement circuit, and I want to tie it in to a switched light at the end of run. The light itself is basically a bulb wired into a junction box under the stairs, so how do I overcome the "switched" part of the equation and extend power to the new outlet when the light is switched off? Is this even possible?
Old 07-01-12, 10:49 AM
Tolyn Ironhand's Avatar
Not possible with the current wiring unless it is wired in conduit. If it is, then you just need to add a wire in the conduit.
If it is cable, you can replace the cable with a 3 wire cable (14/3 or 12/3 match the existing) from the switch to the light. However, it might be just as easy to run a separate 2 wire cable from the switch to the new outlet.
IS there just a black and white in the light box?
Old 07-01-12, 10:51 AM
ray2047's Avatar
Unless the light is wired with three conductor cable (white, black, red) there is no simple solution. Easiest would be to find a source of constant power for your new receptacle.
Old 07-01-12, 11:16 AM
It is 14/2 wiring in the light box, and the switch is located in a finished wall so running a new cable might be a bit of a challenge. I think there is another receptacle I might be able to tie into, so I will try and go that route. Thanks for the speedy reply and suggestions guys.
