Reload this Page >
Low voltage lighting - transformer timer dial gets stuck when turning lights on
Old 07-01-12, 04:29 PM
The timer on the transformer for the landscape lights in the front of our house will sometimes get stuck and not turn the lights on - the timer is the dial type, with little red and black tabs to set the turn-on and turn-off times.
I can rotate the dial by hand through the full cycle of turn-on, turn-off, and turn-on again, so its not locked up, and the lights come on just fine.
It doesn't get stuck every time, maybe 75%, but only at the turn-on tab.
What can I do to troubleshoot this problem - is there something I can do to loosen up the movement?
Thanks
Old 07-01-12, 05:38 PM
ray2047's Avatar
I doubt it is repairable. You can contact the manufacturer. Maybe they will send you a replacement free as a goodwill gesture.
