Troubleshooting a GFCI Circuit
Received 0 Votes
I have a single pole 15A Square "D" circuit breaker feeding a single 15A GFCI receptacle. The15A GFCI receptacle powers a Zoeller Corporation Qwik Jon Grinder pump. The GFCI receptacle keeps tripping off. As the receptacle was over 10 years old, I opted to replace the original 15A GFCI receptacle with a new one. However, the GFCI receptacle continues to trip off. As soon as I attempt to reset the receptacle, the Grinder pump kicks in and the GFCI receptacle immediately trips off. What might the problem be? There is no moisture in the area of the GFCI receptacle.
Sounds like something is wrong with the grinder, as the receptacle trips when it comes on. Can you turn off the grinder to verify it is the cause of the receptacle tripping by resetting the receptacle and then turning the grinder back on after a delay?
Received 0 Votes
Grinder Pump Reset
The only way to turn the grinder on and off is to unplug it from the receptacle. I can unplug it, reset the GFCI receptacle, wait a period of time, and then plug it in once again and see what happens.
