new wiring construction
Old 07-03-12, 07:03 AM
This is my set up I am using for a portable building 10x 12 inside dimensions
breaker panel on outside pole 30 amp
wire from breaker pole to inside breaker panel 10/3
inside breaker panel 2 breakers 20 amps
circuit 1 1 15 amp outlet
circuit 2 1 15 amp outlet 1 light fixture (Ceiling fan)
Heaviest load will be on circuit 1 as that will be used for a 5k btu ac window unit.
Question:
Will the 30 amp breaker on the outside pole be sufficient or do I need to run a 40 amp breaker.
I know I could have used 12 gauge wire on the outside line but I wanted to future proof the outside feeder if I ever needed more power.
and yes I probably over engineered this set up.
Old 07-03-12, 08:10 AM
ray2047's Avatar
You could not have used #12 on a 30 amp breaker. Your plan sounds fine and you have capacity for more branch circuits in the subpanel. Just be sure to add an eight foot ground rod, a bonded ground bar and isolate the neutral bar.
Old 07-03-12, 08:45 AM
SeaOn's Avatar
I agree with ray
Old 07-03-12, 04:41 PM
CasualJoe's Avatar
What type of cable are you using to feed the panel in the building? If this is SO, SOW, SJ or similar type cable you should have used 10-4
Old 07-03-12, 06:05 PM
Justin Smith's Avatar
Is this a 120 or 120/240 circuit? If it's 120/240, you need 10/4.
Old 07-03-12, 06:12 PM
...inside breaker panel 2 breakers 20 amps
Using 12ga wire no doubt. Just making sure...
Old 07-03-12, 06:34 PM
pcboss's Avatar
Flexible cords like SO, SJO, SOOW and the like cannot be used in place of permanent wiring.
Old 07-03-12, 06:45 PM
This is a portable building, he has to use this.
Old 07-04-12, 07:07 AM
will the ground wire and set up circuit on the outside breaker box be sufficient for grounding or do I need to run a second ground bar there is only a total of 25 ft distance (Wire length not straight line distance) from point to point between the two breaker boxes.
When I buried the conduit I placed bricks over the top. I figure if they can't guess from the two ends of plastic conduit and the bricks there is a wire in the ground I want to sit back and watch the fireworks with a beer in my hand laughing when they dig it up.
I ran 12-2 wire on the inside. This particular building will never be upgraded. IF it is I will have to install a larger box as I only have a 2 breaker panel box inside It is for a small retail shop. the future proofing is in case I ever end up moving the building from the property and they put another building in.
Old 07-04-12, 07:31 AM
ray2047's Avatar
How deep is the conduit" What kind of wire did you run? THWN?
Wire length is not a factor. The subpanel must have an isolated neutral bar and a bonded ground bar. Since ground bars are not usually included you would probably need one. In addition you need a ground rod driven eight feet in the ground. Both the EGC* from the main panel and the GEC* from the ground rod go to the ground bar. The GEC can be as small as #8 but if you make it #6 it will not need to be in conduit.
*Definitions
EGC= Equipment grounding conductor, the green or bare wire from the pole panel.
GEC= Grounding electrode conductor, the wire from your ground rod
Old 07-04-12, 11:06 AM
SeaOn's Avatar
The GEC can be as small as #10 but if you make it #6
The minimum size a GEC can be is a #8.
Old 07-05-12, 04:12 PM
CasualJoe's Avatar
Both the EGC* from the main panel and the GEC* from the ground rod go to the neutral bar.
Ummm...Ray, I think you meant ground bar.
Old 07-05-12, 04:26 PM
pcboss's Avatar
CJ, thanks for the catch. I changed Rays post.
