Dead receptacle, two hot wire feed... need some help
Old 07-12-12, 12:46 AM
I just moved into a house and it has a dead receptacle. There's power coming into it. When I attach a prong to both it reads DC... weird I know. So I decided to run a extension cable to the receptacle to test it out. Here is a diagram of my findings. There is also two white wires attach to C and D that feeds to the outlet on the otherside of the wall.
Old 07-12-12, 02:54 AM
chandler's Avatar
Received 6 Votes on 6 Posts
Welcome to the forums! When you said you ran an extension cable to it, exactly what did you do? Your drawings are good, but would it be possible for you to remove the power from this receptacle and pull it from the wall and take a pix or two so we can see what you have? How did you determine this was producing direct current? http://www.doityourself.com/forum/el...your-post.html
Old 07-12-12, 08:20 PM
Nashkat1's Avatar
Received 2 Votes on 2 Posts
Do you mean that there's a cable with a black wire and a white wire in it, with the white wire attached to C and the black wire attached to D, that feeds a receptacle on the other side of the wall?
Are you using an analog meter? The 24V sounds like induced voltage, which analog meters are generally better at shedding than digital meters are.
