wiring help with 3-way receptacles
Received 0 Votes
I am updating some of the outlets and switches in my garage and I need a little help with the right wiring configurations that I need to finish the job.
The power is coming into a receptacle box and then feeds the switches and another outlet. Diagram is below. I would like to know in what place to the wires connect too. I can't seem to find this in any of the diagrams that I looked at.
Thank you in advance
Welcome to the forums! Yeah, we need to know what the three way switches are controlling, whether it be light fixture (s) or that receptacle. If it is the receptacle, this may help. If not, post back with more information and we can help.
Attachment 1978
Attachment 1978
Received 0 Votes
The 3 way switches operate both of the receptacles. The receptacles are in the ceiling and the shop lights are plugged into these. So the switches are needed to turn on and off these lights.
Received 0 Votes
Chandler,
Thank you for your response.
But, the diagram that you show does not reflect the problem that I have. The reason is because the source is coming into the the receptacle and then branching off into the 2 3 way switches and then another receptacle.
This forum is almost the same as mine, but I cannot see the pictures. I do not know why.
http://www.doityourself.com/forum/el...ptacles.html#b
Good! I'm not good drawing diagrams on the computer but I will give it a try:
Mark both whites going to the 3-ways with black tape
Alone receptacle:
Wire as normal (black to brass, white to silver, bare to ground)
Alone receptacle:
Received 0 Votes
I understand that, but it is already wired this way. I moved a switch location, and I thought I rewired it correctly, but apparently did not. I just need a diagram to go off of. The below picture I can't see where all the wires go.
I only see 2 wires that connect to the incoming outlet. What other wires are connected?
- Incoming hot spliced to the "white" (tagged w/black) to the common (usually black) terminal on the upper switch.
- Travelers (red and black in the 3-wire cables), terminated on the brass screws on each 3-way switch, spliced color-to-color in the box where the power enters.
- "White" (tagged w/black) from the common terminal on the right-hand switch spliced to the black wire feeding the "away" receptacle and to a black pigtail for the "near" receptacle.
- Incoming neutral spliced to the white wire feeding the "away" receptacle and to a white pigtail for the "near" receptacle.
