Proper ground attachments.
Old 07-19-12, 02:55 PM
D
Received 1 Upvote on 1 Post
What is the best way to attach all of my grounds together? I need to bring my cable and telephone grounds to the same point as my service ground. Should I do this in the service panel, at the acorn clamp, or some other way?
Old 07-19-12, 03:06 PM
F
The shortest and most direct is best. Probably a split bolt connector on the conductor actually going to the grounding electrode.
Old 07-19-12, 03:17 PM
P
In National Electrical Code parlance this is referred to as "Intersystem Bonding". Art 250.94 requires such terminations be made at , and external to , the enclosure of the Service Panel. Available are Bonding terminations designed for this specific purpose.
Old 07-19-12, 03:21 PM
F
One such device...
[ATTACH=CONFIG]2000[/ATTACH]
(Image courtesy of designworldonline.com.)
Old 07-19-12, 05:42 PM
CasualJoe's Avatar
Received 179 Upvotes on 162 Posts
Old 07-19-12, 07:18 PM
D
Thanks guys. I actually ordered one of the Arlingtons. I'll probably see it on Monday.
I did go out and inspect my ground wire and electrodes. The one clamp was loose so I tightened that up.
