grounding a metal outlet box
Old 07-24-12, 08:02 AM
R
Does code require a separate grounding wire for a metal box containing a 50 amp 220 volt receptacle, even though it's already grounded through the metal cover attached directly to the receptacle ground?
Old 07-24-12, 08:29 AM
ray2047's Avatar
Yes. The ground wires need to be connected together and pigtailed to the box using a 10-32 machine screw in a tapped hole.
