Installing ceiling light fixture in very old wiring that has never worked.
Received 0 Votes
Been in this house +20 years and bedroom ceiling light never worked from day one. Changed bulbs, no help, but wife did not like it anyway because we had a floor lamp.
Now, thinking about moving, it's time to fix that light. New wall switch, no help. Bought a new ceiling fixture. Turned breaker off, switch off, removed old fixture and cut the two old insulated wires, no color code, no ground. [110 year old house]
Turned breaker ON, but silly me, left the wall switch OFF. Using a blinking squealer, the wire on the left squealed. Nothing on the right wire.
Looking back, I suspect this was my mistake. I should have turned the wall switch on and tested. That should have shown me the hot wire.
Perhaps by mistake, I assumed the left wire was hot, and connected the two black wires from the new fixture to the left ceiling light, white wires to the right ceiling wire, and did nothing with the fixture ground wire.
Still not working. I figure I connected the wires backwards.
Questions:
1-if I hooked them backwards, shouldn't the lights still work? [although unsafely]
2-if the connections were backwards, why wouldn't it pop the CB?
3-does my theory above make sense, that I connected them wrong?
4-perhaps the biggest Q: if there is no ground wire from the metal ceiling box, how do I test to find the hot wire? If I use a VOM, it will show 115 mystery wire to mystery wire. How can I tell which is hot?
5--Even in this old house, do you think the metal ceiling box is grounded through a conduit? Everything in this old house is tube and tie. The only ground wires are those I have added when installing AC, outside flood lights, etc.
many thanks
Questions:
many thanks
Received 0 Votes
"Plug an extension cord into a receptacle that you know is wired correctly. At the ceiling, with power and switch on, insert one probe from your analog multimeter (your VOM) into the neutral (larger) slot of the extension cord end. Touch the other probe to each wire in the ceiling. Mark them with short lengths of black and white electrical tape."
Ah, so simple and yet very clever. Obviously, never thought of that. The fixture is at one end of the house, and almost impossible to reach or even see through the attic trapdoor. [I'm in my 70's and don't crawl around attics]
Since the wiring is so old. and the insulation rather thick, I assume I didn't scrap them clean. Making matters worse, it's a 10' ceiling over the bed. I have to lay plywood on the bed, then a step ladder on top, and a friend to keep me steady as I do this. And the fixture was a b**** to install. Not anxious to do this again, but will sure follow your steps.
many thanks
more--just thought of this. If I use a 3 wire ext cord as you describe above, I could also check for continuity from ceiling box to grd wire on ext cord. Right? If the entire house is grounded, it should indicate continuity?
many thanks
You can measure voltage from the box to the black wire to check for ground. Of course if you have old style BX with no bonding wire you may show ~120v but still not have a really could ground.
BX is a type of flexible metallic cable. Though it some cases it might actually be flexible metallic conduit, AKA Greenfield.
Source: BX cable: Definition from Answers.com
