How to determine the wattage for lamp - electrical transformer
Received 0 Votes
Hello,
I feel like I am asking a stupid question here but I'rather be safe than sorry. We are moving to Europe and will bring a few lamps with us. Since everything is in 220v over there, I need to buy a few transformer. Based on what I can read, you need to buy transformer that support the wattage of the appliance you will use it for (you apply some rati depending on the appliance).
So here is the stupid question, for lamps, how do you determine the max wattage? Is this equal to the wattage of the bulb you put in?
Thanks.
Thanks.
Received 0 Votes
Electrical converter 220v to 110v - What to choose?
Hello,
I am moving to Europe for a while and need to buy some converters for lamps, power tools, etc...I can't tell if there are some reputable companies that sell such things (when you google, you find a bit of everything) and I don't want to get something that will catch fire or something.
It seems that products from the company seven star come up quite often but I had never heard about them. Do you know what to look for when buying such things and who makes good products?
Thanks.
Thanks.
But why do you ask? Are you planning to take your lamps to Europe, rather than cash? And plug the lamps into the local power? If you are, and you're planning to use plug-in converters to give you 120V for the lamp, than the answer there is the same as the answer here.
Google "Travel Voltage Converter" Biggest thing to look for is that it has enough watts to handle what you want to run. This one: Foreign Travel Voltage Converter Adapter Kit SS204K- Seven Star-Computers & Electronics-Power & Cables-Adapters Can handle 1600 watts while this one: Amazon.com: HDE (TM) Travel Voltage Power Converter Adapter 220v/110v 110v/220v: Electronics can only handle 80 watts. I do not have any experience with these so I can only recommend buying from a reputable store.
I merged two threads that were asking the same thing.
You need to consider that many European countries have 50 cycle power.
Even though you can lower the voltage the frequency will not change and some electronics don't work well on 50 cycle.
Received 0 Votes
Thanks for the feedback. I am just planning to take a few lamps that were not cheap as well as some power tools (I just need to power the battery charger as these are cordless tools).
For the lamps, I will see if I can get someone to rewire them while over there but in the meantime, I'll use a down converter.
Received 0 Votes
Sorry for the somewhat similar questions. I was trying to separate the questions to the right forum as one for for lamps wattage and the other more general.
In term of frequency, for lamps and a battery charger (We are not bringing any electronics), do you see any issue?
If the lamps are just incandescent with a simple switch they would be ok, a fluorescent or dimmer controlled lamp may not be.
Most battery chargers have charge controllers in them which are electronic so you would have to check with the mfr to see if they would work.
What country are you going to?
I will be in France at first.
You won't be able to convert the cycles, so look for 230V to 120V conversion and make sure whatever you're taking can deal with 50Hz. As Greg noted earlier,
Assuming lamps using standard incandescent bulbs just make an adapter plug and use a 240v bulb.Bulb example: 60A/220 (220-240V) - 60 Watt, 220-240 Volt A19 Frosted Bulb | Bulbs.com.
Received 0 Votes
Don't I have to be worried about the lamp wires? If not, I guess I just use a plug adapter. This would be easier and cheaper...
In addition, thinking about it, it is quite likely that I will only find CFL screw-in light bulbs in Europe that are meant for 220V (I believe it is not illegal in France to sell standard incandescent bulbs). So using a down converter might force me to import the light bulbs....Jeez.
I am not really sure about this, but I believe it's possible the switches in lamps purchased in the states may only be rated for 120 volts. I never really had to worry about it, lamps don't fit very well in an overstuffed duffel bag! Does anyone know for sure?
There are different viewpoints on this but I believe you really should adhere to the voltage rating on the wire and switches.
The approval for the device is based on the electrical specs for the country it is approved in.
Well....not really an answer to the question....but why not just buy what you need locally then sell them when you are done? Since the tools are cordless...you'd just need a charger. I'd guess most major brands sell in Europe as well as the US.
Sure...you'll lose some money....but you'll lose money if you buy a bunch of converters and then have no need for them when you come back.
Received 0 Votes
"Don't I have to be worried about the lamp wires?
No. The same gauge wire will supply more watts at higher voltage. Wires are rated for the maximum amperage they can safely handle.
Just to make sure I get it, are you saying that I can just used a plug adapter and light bulbs rated for 220V and I will be fine.
