Wiring a track light without junction box?
Old 08-03-12, 08:04 PM
I'm going to be installing a track light soon in a room that does not have a junction box in the ceiling. I have an outlet that's controlled by a regular switch which I'll be changing to a dimmer as well.
Here's my question. Without the junction box, can I install the track light by running the wire through the ceiling, down behind the wall and hard wiring it to the outlet? I would remove the plugs and then put a blank outlet cover so it can't used with plugs.
Old 08-03-12, 08:15 PM
Nashkat1's Avatar
Welcome to the forums!
Without the junction box, can I install the track light by running the wire through the ceiling, down behind the wall and...
That depends on whether the live end of your track light is rated to be used as a junction box. Many are. What product are you planning to install?
...hard wiring it to the outlet?
Why do you want to go to the outlet (I'm guessing you mean a receptacle mounted + 16" above the floor) rather than to the switch?
Note: Removing the receptacle from that location may create a code violation relative to required receptacle spacing.
Old 08-04-12, 06:18 AM
chandler's Avatar
You can't dim a receptacle, so rethink that. Remove the power to the receptacle and pull it from the wall. Tell us the configuration of the wires attached to it. Or better yet, post a pic of the receptacle. There's ways to do what you want, but better than what you are describing. http://www.doityourself.com/forum/el...your-post.html
