Quick question about Cooper Decorator light switch
Received 0 Votes
I'm replacing old toggles and receptacles from the mid 80s with Cooper Decorator receptacles and switches.
I was told by an old electrician that you shouldn't use the stab in wire connections and should wrap the wires around the terminal screws. So I have been following this idea as I swap out receptacles. Now on the Cooper switches, they have the stab in and the terminal screws have a back plate meant for wedging the bare wire under the plate using the pressure from the tightened screw.
So my question is......do I ignore the back plate and continue to wrap the terminal screw with the wire or should I be using the back plate which essentially looks similar to the stab in scenario?
Thanks!
Thanks!
I agree. There's a difference between "backstab" and "backwire". Stab is held by spring tension, back wire requires you to tighten the screw.
Backstab is bad...mmmkay? Backwire is good...mmmkay?
Sorry...SP episode on the tv.
