Generator efficiency
Received 0 Votes
My 7 kW Generac LP powered generator has a 14.5 horse power engine.
Using the formula 1 hp = 0.7457 kW would mean it requires 9.4 hp if the generator was 100% efficient. So does this mean my generator runs at 65% efficiency?
How do these portable generators get ratings up to 8 kW?
It is a combination of efficiencies but you are correct that the end result from a purely mathematical perspective is that you only get a fraction of the heating content of the fuel used back as electrical power.
Almost any generator will have peak outputs exceeding their continuous load outputs. It is a matter of heat, mostly getting rid of excess heat, that limits the peak output to a short period of time. There is also the peak output of the prime mover (engine) to consider.
Read more: http://www.doityourself.com/forum/ne...#ixzz23tHmm3zy
For example, can't remember if they still do but, the 20 kw was rated for 18 on natural and 20 on LP. It was like 7/8, 13/14, 16/17, 18/20 natural/LP
Received 0 Votes
That is correct that NG has less horse power than LP on the model type I have.
But I was just looking for the typical efficiency of the electrical generator, not the engine efficiency.
Do some have better designs (maybe permanent magnet type) then the one I have which has a two pole rotor and stator?
Received 0 Votes
The best method of determining the performance of you generator is to calculate the amount of gas , measured in cubic-ft , that is consumed when the generator produces one Kilo-Wattt Hour of electricity.
You could connect an exact load of 1000 Watts to the generator and run the generator for exactly one hour, but you would need a gas-flow to measure the volume of gas consumed during this one-hour period.
Possibly there are "gas-experts" in other sections of this DIY Forum who could advise you on the practicality of connecting a gas-flow meter to your system.
