Electric to shed
Electric to shed
I realize there are probably 1000 posts on this subject already but wanted to get some personalized opinions.
Basically here is the plan: This is about 100' run
Run 10/2 off a 20A GFCI breaker at the main panel of the house.
Run this 12" deep in pvc conduit
Comes into a kill switch in the shed where it comes out as 12/2 for the recepticals and single light fixture
Power needs:
1 5000BTU Window AC unit (4.8 A, 115V)
2 Computer Monitors (1 A x 2 )
3 Desktop Computers (1.5 A x 3 )
1 Light fixture (2 32W fluorescent light bulbs)
Opinions?
I need to take two things into consideration:
1st. - Price (I have a rather low budget for the project)
2nd. - Knowledge (My first time doing an electrical project. I will have a friend that works as an electrician helper coming out to work with me)
Power needs:
Opinions?
Karlrith,
Depending on where you live, the rules for underground wiring vary. Stop by your communities city hall and talk to the electrical inspector. In some areas, you can use a "direct bury" wire and not even use conduit. The depth of the bury varies also, so if you want to be "by code", just ask. If you run a # 10 2 w ire with ground, you can use a 30 amp breaker which will more than cover the amp draw you are requiring. With all the computers you are planning to use, I would also recommend a good sized battery backup unit with surge protection.
You could run a 30 amp feeder to the building but you would need to install a breaker panel at the building. General purpose circuits are limited to 20 amps.
You would be better off to run a 10-3 feeder than a 10-2. You would be able to run more or have expansion room for later.
If feeder is 20 amps or less and GFCI protected, 12" burial depth is fine.
However, I am with PCboss and suggest running a 10/3 cable, using 30 amp breaker, and adding a small panel. This will more than double your wattage available. That would need to be buried 18" minimum.
A small panel can be had for about $30 or less.
So I could run a 10/3 cable off a 30 amp breaker out to a sub panel in the shed. From the sub panel i could have 2 20A circuits, correct?
Would this require a ground rod? For what I am going to be running would it be required? The cable itself certainly jacks the price up...
Or if no 240 loads anticipated run 10-3 on a 240 volt 20 amp breaker and wire as a 120 volt multi-wire circuit. That would provide two 20 amp 120 volt circuits with no panel needed, just a disconnect. At some later time it could be converted to a 30 amp 120/240 circuit with subpanel if extra power was ever needed.
This sounds promising, could i get away with 12-3? Roughly 100$ cheaper
If I dug deeper (18") then I could just use GFCI recepticals, correct?
So I could run 12/3 18" underground from a 240V 20A breaker from the house to a two pole switch in the shed and turn it into 2 120V 20A circuits coming out of switch? That sound right?
Thank you everyone for your help!
