Trouble installing vacancy sensing wall switch
Received 0 Votes
I live in Saginaw county, Michigan and my home was built in 1977/78.
I purchased several vacancy sensing switches to replace my existing wall switches to save $$. The switches operate the ceiling room light. I purchased a Pass & Seymour, 0-600 watt, 120VAC, 1/6 HP switch at Menard's. The new switch has 3 wires, black, red and green.
I shut off the breaker at the box, removed the plate from the wall switch and took off the existing wall switch and observed there were 2 black wires to the top terminal of the switch and one red wire to the bottom terminal of the switch. There are no green wires going to the switch. There are white wires in the box but they are capped at the back of the box and do not go to the switch. I cannot see any bare copper wires (ground) in the box, but it is dark in there.
As the wiring colors and number of the existing switch do not match the new switch I am in a quandry. How should I install the new switch (or do I have the wrong one).
I have attached several photos of the new switch information and wiring configuration as well as a photo of the wiring in the box.
Thank you!
Welcome to the forums!
What appears to be two black wires attached to the switch is actually one wire with a short piece of insulation removed for the termination.
Remove the wires from the switch. Undo the black wire splice. Cut off the end of the black wire that was going to the switch just beyond the mid-wire strip. Redo the black wire splice and add the black wire from the new switch. Splice red to red. Terminate the green wire to the metal box using an approved ground screw.
How should I install the new switch...?
I have been starring at that picture and I can't tell if the wire is looped over the screw or if the screw is black or brass. If the screw is brass colored and there are no black screws on the switch follow Nash's instructions.
Just a observation, in those switch boxes with a neutral it would be better to go with an occupancy switch that has a neutral, That way the occupancy switch can be used with CFL bulbs and fluorescent light fixtures. Of course there is no reason to assume all your switches are wired the same way so each switch must be evaluated separately for the correct switch to use.
Received 0 Votes
New information on vacancy sensing switch install
I rechecked the box and took another photo. there are definitely 2 black wires coming into the box. The copper wire at the back of the box appears to the ground. this may have originally been a 4 way switch that connected the light to a switch at the top of the stairs and one in the hall but was not hooked up correctly? This 2nd photo of the box may show the incoming black wires better.
So is this now hooked up as a single location switch or a 3-way switch with two switches that operate the same light? In other words is this a single pole single throw switch or a 3-way single pole double throw switch?
Received 0 Votes
The switch presently is a single location switch. I would like to install the vacancy sensor switch as a 3-way switch with two switches that operate the same light but not sure I can do this.
The vacancy switch won't accommodate a 3-way that is why I asked. You need to determine which incoming wire is hot using a multimeter or test light but not a non-contact tester by measuring each wire to the white bundle. That wire goes to the black of the VSw. It is probably the black on the switch. If so then the red on the existing switch goes to the VSw. red.
Not the first time I've been wrong.
So now I'm guessing that the two black wires are joined by being connected to the same terminal on the existing switch. Is that correct?
If so, and if you want to install your VSw to do what the old switch was doing, remove the two black wires from the switch and splice them together with the black from the VSw. Then connect red-to-red and green-to-ground. You should use a jumper from the new ground-and-green splice to bond the box to ground, unless it already is.
I think I see a ground clip at the top left of the box.
Robbie, that answers that question. Now the challenge is finding a way to connect the green wire from your VSw. that might be most easily done by connecting it to the bonded metal box with a ground screw
Received 0 Votes
Yes, the two black wires are joined on the same terminal of the existing switch.
Let me see if I have your instructions correct: The two black wires on the same switch terminal, made a 3 way switch into a single pole switch. To keep this single pole configuration I should
a. splice the two black wires from the box to the black wire of the new vacancy switch and
b. connect the red wire from the box to the red wire of the vacancy switch.
c. connect the green to the ground
The instructions for handling the ground wire have me confused. The bare ground wires at the back of the box have no "ends" for me to splice the green wire. What do you mean "use a jumper?" There is no screw hole at the back of the box to put in a screw to attach the ground wire. Still a bit confused.
Thanks so much
Thanks so much
The two blacks on the same screw are improper, one wire per screw. They are using the screw to act as a splice between the two blacks. You need to add a pigtail to fix this.
You can add a piece of bare to allow you to ground the new switch.
Originally Posted by Nashkat1
Would you prefer to see whether you can have multiple switch locations with your existing wiring, or just install your VSw to control the light that the switch in this box has been controlling?
So:
