Rodog: Motor Question
Old 08-31-12, 12:13 PM
R
I have a question on mine. Its a 240v Ingersol Rand. It originally had 12awg wiring from junction to motor. Is it ok to power the motor with 12awg? or should i use 10awg. The baldor motor on it says 25-23 amps....
Ingersoll-Rand Type 30 Air-Compressor - 1968 - Restoration Part 1 - Before - YouTube
Old 08-31-12, 01:45 PM
Nashkat1's Avatar
Received 5 Votes on 4 Posts
mine... originally had 12awg wiring from junction to motor. Is it ok to power the motor with 12awg? or should i use 10awg. The baldor motor on it says 25-23 amps....
Do you have the Baldor spec sheet on it? If it's drawing 23-25 amps per leg, it should be wired with 10AWG conductors protected by a 2-pole 30A breaker.
Old 09-01-12, 01:08 PM
Tolyn Ironhand's Avatar
Received 551 Votes on 473 Posts
I agree with Nashkat, go #10.
However, the branch circuit breaker can be as high as 70 amps. I would not go that high, start at 30 amps and see if it will run.
Old 09-01-12, 01:36 PM
R
Someone re-word my post. Its running fine. Im going to rewire it with 10awg. You guys see the video?
