Solid Wire vs. Stranded Wire?
Received 0 Votes
Can extending a solid wire circuit with a larger gauge stranded wire be a fire hazard?
Received 0 Votes
My friend was extending an outlet that had a solid 12/2 wire ran to it with a stranded 10/4 wire, the insulation was so thick he could barely get it in the box!
Received 0 Votes
The wire being stranded is the only reason it's flexible! The solid 12/2 Romex was flat and gray, the stranded 10/4 cable was thick, round and black!
Received 33 Votes
Thick, round, black cable sounds like type S (with a few more letters) flexible cable and that is not suitable for fixed wiring. Can you read the jacket on the cable? Does it say something like SOOW or SJ or anything similar? Is this in conduit or behind a finished wall or just run in the air?
Received 0 Votes
Yes, the cable says 10/4 SOW and it's ran in open air!
The size is okay but not the type of cable.
That sounds like it was not Romex but was UF. If this is outside he should replace the SO cable with UF cable (but not Romex/NM-b) immediately and run the UF in a manner that does not expose it to damage. Please tell us more details about what he is doing and we can better advise him.
Received 33 Votes
A few pictures of the installation would also be helpful.
http://www.doityourself.com/forum/el...-pictures.html
Received 0 Votes
I'll take some pics of it asap, he's on a ranch out in the middle of Cave Creek, AZ! He also wants to add some outlets to his well house so I'll take pics of the existing electric circuits!
Previous Thread
Next Thread
