ungrounded outlets
Old 01-24-01, 07:05 AM
Guest
Question on ungrounded outlets--first time on any forum--with grounded neutral system and two prong plugs is it permissible to install three prong plug with green jumper wire from neutral screw to ground screw??
Old 01-24-01, 07:15 AM
Absolutely not. This is very unsafe.
There is no easy way to get grounding, but there is an easy way to get three-pronged plugs: install GFCI.
This is the condensed version. Post back if you want more info, and/or read the recent post by mw with the exact same subject as yours.
[Edited by John Nelson on 01-24-01 at 10:23]
