Outlet Problem
Received 0 Votes
Outlet Problem
Looks like I have another problem to add to the first one (http://www.doityourself.com/forum/el...witch-fan.html). Yesterday switched out a outlet for a new one. Everything worked fine until this morning, plugged something in and nothing.
Looked at everything and all screws are tight thought I may have switched the wire around so changed the black wires around, nothing, put them back like they where, nothing. Tried another outlet, nothing, switched the wires around like the first time, nothing. I have 4 wires in total, one white and one black coming form one side of the box, and the same thing on the other side of the box. Originally each black wire went with the opposing white on the receptacle (I think). I have no idea what is wrong, any ideas? Maybe I put the wires on wrong? Maybe wrong combination?
If this is not a GFCI receptacle it doesn't matter which brass screw each black wire goes on and it doesn't matter which silver screw each white wire goes on. Did you use the screws not the back stabs? did you leave the tabs between the screws in place? Have you checked with a multimeter or test light but not a non contact tester to see if one of the cables is hot?
This is what it looks like and it is in the restroom, no GFCI.
If you need to supply the GFCI protection here, and you aren't clear about how to connect it, post back. We can help you with that.
Is this receptacle in a bathroom? If so, does it have GFCI protection from a breaker or device upstream?
Note: Wires are not connected to a GFCI receptacle by curling and crimping them around the screws. They are inserted into the back-clamp slots and the screws are tightened to close the clamps. In addition, the wires from each cable must be connected to the appropriate pair of terminals, either LINE or LOAD.
