damcs: Is a relay required?
Old 09-26-12, 07:46 AM
Hi, I am rewiring a guest bathroom and was thinking about having an incandescent light and fan on a motion sensor. If I have both connected to the same sensor, would the relay described in the above post still be required for the fan? Does anyone know of a motion sensor that is specifically designed for use with a fan? Thanks!
Old 09-26-12, 08:12 AM
Post was moved, here is the link to the original thread I stumbled across when researching. Thanks!
http://www.doityourself.com/forum/electrical-c-d-c/453508-bathroom-fan-wall-motion-sensor-110v-relay.html
Old 09-26-12, 08:25 AM
ray2047's Avatar
No relay is needed so long as the amp/watt rating for the sensor is not exceeded.
