How deep does PVC need to be in concrete slab?
Received 0 Votes
OK in preparation for the kitchen island - I'm cutting a channel into the slab to run electric (about 2' from the wall)- I cut down about 2.5" and about 3.5" wide in the concrete - I rented a power chisel. To go deeper seems to really be a challenge- Can I lay the PVC in and cover with concrete from here? What determines the depth that it needs to be? I can't see weight being an issue- Once the concrete hardens around the PVC and the floor gets installed.....thoughts? suggestions?
PVC is my second choice for conduit in concrete. My first choice is smurf tube, for ease of working. No metal pipe or fittings in concrete - they will corrode.
That said, 1-1/2" to the top of the pipe seems a bit shallow. I like 4" of concrete over the pipe, even when that means that the bottom of the pipe is lying on the gravel bed. Slicing the slab with a diamond-tipped circular blade on the end of a saw before hammering the center out makes the work go faster. A masonry saw should be available for rent locally.
Welcome to the forums!
When you say
are you saying that the pipe should be deep enough that the bends should finish below the surface, and the pipe emerge as a vertical run?
When you say
You need to make room for the turns or elbows you are using bends correct?
yes elbows fit fine when I test fitted them
While you do need a continuous run of conduit, guarding against damage during the wire pull is not really a concern with a little run like this. If they fit fine and turn up where you need them, you should be good.
