10/4 MC for 240V Dryer?
Old 10-09-12, 09:52 AM
Hi all,
I'm looking to have a new dryer circuit put in. I'll get an electrician to add in the circuit, but I'm thinking of doing the rough-in myself.
The dryer is 240V and should be on a 30A circuit, per the manufacturer. The cable needs to run about 50ft in an unfinished garage.
As far as I understand, I should use 10-gauge wire, protected. However, I'm having trouble finding 10/4 MC/AC cables anywhere. The store has 10/3 MC (and the dryer can use 3- or 4-wire), but I'm thinking that 4-wire would be better.
Does 10/4 MC/AC exist? Or do I have to run cables in a conduit?
Thanks!
Old 10-09-12, 10:15 AM
Nashkat1's Avatar
The dryer is 240V and should be on a 30A circuit, per the manufacturer... I'm having trouble finding 10/4 MC/AC cables anywhere. The store has 10/3 MC... Does 10/4 MC/AC exist?
Not really. You need to look for, and ask for, 10-3 MC WG (with ground). You should be able to find it at an electrical supply house if the Big Box stores don't have it.
It is, and it's required for compliance with modern codes.
That said, a 250' coil of 10-3 MC WG will probably set you back nearly $400.00. Unless you can find a supply house that will cut you the length you need, the individual conductors in conduit might be less expensive, as well as a cleaner install.
Old 10-09-12, 10:16 AM
Glennsparky's Avatar
10/3 with ground has 4 wires, black, red, white and green. Yes, four wires is better.
Old 10-09-12, 10:18 AM
ray2047's Avatar
Actually you need 10-3 MC. . The "3" refers to the number of conductors and does not include the ground in it's total. MC will have a ground wire in addition to the three (red, white, black) conductors.
Old 10-09-12, 11:14 AM
Thank you guys! That explains it
Old 10-09-12, 05:10 PM
CasualJoe's Avatar
Why is it you want to use MC cable rather than NM B cable (aka Romex)?
