[Ground Rod] location
Old 10-10-12, 08:47 PM
When running service to a detached building, does it matter if the grounding rod is inside the building or outside? The floor of the buildings field stone laid in a thin concreate bed that is failing in spots so it may be possible to sink the rod inside the building.
Thanks
pagebu
Old 10-10-12, 08:50 PM
Justin Smith's Avatar
It needs to be where it'll be permanently moist.
Old 10-11-12, 06:24 PM
CasualJoe's Avatar
I don't think the NEC prohibits installing the ground rod inside through the floor, but I would rather have it outside.
Old 10-11-12, 06:28 PM
lawrosa's Avatar
Super Moderator
Are you supposed to have a ground rod? I thought that may take away from the main homes ground rod, or something like that?
Just asking.....
Old 10-11-12, 06:40 PM
ray2047's Avatar
Any detached building served by a feeder must have at least one grounding electrode, usually a ground rod or ufer. Often two ground rods are used to avoid having to prove one is enough. (Article 250 NEC).
A multiwire branch circuit to an outbuilding is considered a single circuit and no electrode is needed.
Also a means of disconnect is required.
Old 10-12-12, 10:31 AM
Nashkat1's Avatar
If you're creating a subpanel in the detached structure, then yes. It will add to, or supplement, the service entrance grounding.
