Proper Pigtailing?
Old 10-22-12, 05:22 AM
Proper Pigtailing?
When installing multiple switches running off the same circuit, do I make multiple pigtails from the hot, or do I run the hot to one switch and then pigtail each subsequent switch from the previous? I'm trying to run 4 switches off one circuit for various lights. If I tried to pigtail each switch from the hot, that would be 5 wires - can I do that? (14/2)
Same question for two duplex outlets?
Old 10-22-12, 06:35 AM
ray2047's Avatar
That is best practice. You can only have one wire per screw and it is best not to use a back stabs as a splice because of their unreliability and confusion it might cause a non-pro at a later time. The old practice of a continuous wire with small sections of insulation removed at each switch can be used but my opinion is it makes it harder to position the switches in the box.
It always depends on box fill and when in doubt you should calculate box fill. More Wires Need Bigger Boxes - Fine Homebuilding Article
Old 10-22-12, 01:32 PM
Nashkat1's Avatar
What is the question about the two duplex outlets? Combining all of the wires on each phase into a splice with a pigtail that connects to the receptacle is generally the best practice.
Old 10-24-12, 08:49 PM
say you have a 3 ganged box with 3 switches then you would take the hot wire and make 3 pig tails off of the switch about 6 inches in length or long enough for convienece. thats a total of 4 wires under one wire nut
