7 wire kitchen outlet wired wrong
I am trying to switch my outlet (nothing wrong changing from white to black outlet) and it is not working. There are 2white wires pigtailed and the ground wire, then there are two black and two red wires. The white is attached to the top silver side, and ground to bottom left ground screw. Then one black wire is in the back top "push in" and one red is in the bottom "push in" then one black is attached to the top right brass screw and the red on the bottom. I did break the brass link on the side, however I am in able to turn on the power. Something is wrong but I don't know what. Any assistance would be great,
<Following assumes this is not a multi wire circuit but is a half switched circuit. Be sure before wiring.> The wires stabbed in the back were a lazy man's splice. It is critical that you keep each pair spliced that way together then pigtail them for the new receptacle. I suspect you mixed up a pair on the new receptacle.
Receptacles don't have a specific orientation so top/bottom left/right are meaningless. Terminal screw color is what is important. Be sure you only break the brass tab. The silver tab must remain unbroken. Attach a pigtail to all the red wires and run it to one of the brass screws. Attach a pigtail to all the black wires and run it to the other brass screw. Attach all the white wires to a pigtail and run it to a silver screw.
Members of this forum recommend never use the back stab connections. They are less reliable the the screws. I'd add never use them as a splice point because they can cause confusion for a non pro.
The room is very limited so not sure I will have room for two more pigtails in there, but I will try. The black and red are on the brass side, and white is on silver side. Only the brass link is broken..... So why do you think I can't turn the breaker on?
The receptacle is just a standard kitchen one above the counter under the cupboard. It also does not appear to be controlled by a switch, but it does have a double breaker switch.
Also is this on a GFCI breaker or are there GFCI receptacles on this circuit?
Kitchen receptacles in Canada are wired from 2 circuits, one to each half as I understand the rules.
