transfer switch questions.
Old 11-01-12, 07:27 PM
I've been looking at a 10 circuit transfer switch, that is part of a kit, that also includes the remote plug, and cord for the generator. This kit is rated for a 7500 watt generator. It lists the max output at 120 volts, at 60 Amps. My question is, the cord is a 10 gauge cord. How is it safe to run 60 amps through it? Could I use a 60 amp NEMA plug, receptacle, and #4 copper? Thanks. John.
Old 11-01-12, 07:35 PM
The generator supplies 30 amperes at 240 volts from a tapped winding. This translates to two, 30 ampere 120 volt feeds. 30 plus 30 equals 60. You cannot pull more than a 30 ampere maximum 120 volt load from either side.
No, you cannot change the cable or the plug and get any more power nor is it necessary to change the cable or plug to get the rated power.
Old 11-01-12, 09:40 PM
Nashkat1's Avatar
10AWG conductors are the proper size for 30A, which is what you're drawing, max.
Old 11-02-12, 05:35 PM
Thanks guys...............
