Water Damaged Electrical Equipment
For those affected by the recent flooding related to Hurricane Sandy, please refer to this from NEMA regarding flooded electrical equipment before restoring power.
Evaluating Water-Damaged Electrical Equipment
Still you may take the risk, just because its not covered by any insurance ... (I know, many of you will, right or wrong, it is a hope, and you want to test it.)
What to do?
Polluted water, sea water etc. is a kind of conductor, so if it has been exposed to polluted water, rinse well.. and do it again. Let it dry, and be sure it is really dry, so let it dry a little bit longer.
Ready for testing? where, how, what if it catch fire, how to protect against electric shock? What about harmful smoke or gases? Is it other risks?
You have to consider, and take care.
If it was me? I have a garage with concrete floor. The outlet is GFCI protected, and I have a fire extinguisher. I will not store anything flammable in the garage during test.
powers witch off -plug in wait a 1/2 minute if OK, plug out, switch on plug in, if OK try to test it out if its working. if OK let it run for a longer period (while you are testing another unit?)
Keep on until feeling safe to take it back home, or if deemed to be defect, cut the cord, and throw it away (follow local regulations for such waist).
Good luck.
dsk
What to do?
Good luck.
dsk
