Can you drill holes vertically through double joists
Old 11-03-12, 09:34 AM
In my house there are 4 holes drilled vertical through double joists that span the length of the house in the middle, then the other joists go perpendicular across each side of the main joist. Obviously this double joist is the main one supporting the load down the middle of the basement. The house is 20 years old, it looks like they drilled four holes vertical through the double joists to run wire. Is this normal or to code? Has anyone seen this done?
Old 11-03-12, 09:36 AM
pcboss's Avatar
I have seen it done, but some inspectors will not allow this without seeing an engineers approval.
Old 11-03-12, 10:59 PM
I just did this on a garage conversion project. I didn't know of any other way to do it. What are some alternative methods for this kind of situation (how are you supposed to do it.)
Old 11-04-12, 07:37 AM
CasualJoe's Avatar
The joist in the picture is nothing more than a typical header made up of two 2 Xs with 1/2" spacers, usually 1/2" plywood, in between them to make up the 3 1/2" stud width. Generally the 2 Xs don't have a full piece of 1/2" plywood between them, but smaller pieces spaced throughout to keep the 2 Xs with a uniform 1/2" space between them and this seems to be the case here as you can see in the picture there is a 1/2" gap between them. My guess is that the two NM B cales are really in the 1/2" space, but someone also ran a drill through there to open the space a little to get the cables through a bit easier. I wouldn't worry about it.
Old 11-04-12, 12:54 PM
pcboss's Avatar
CJ, they looked like LVLs to me, that is why I cautioned about the drilling.
Old 11-04-12, 02:50 PM
CasualJoe's Avatar
They could be and I for a while thought so too, but I do see a definite and distinctive gap between what I now think must be 2 Xs.
Old 11-05-12, 04:28 AM
chandler's Avatar
Jim and CJ, I don't think it is LVL, but Yellow Pine. There would be no need for spacing on LVL since it is 1 3/4" thick to compensate for the plywood needed normally.
Old 11-05-12, 08:29 PM
I took another close up picture, it looks like a very small gap between the two, but they drilled 1/2" hole I think.
Old 11-05-12, 08:43 PM
Maybe that gap is just the wood splitting a little bit because of the hole they drilled, the house is 20+ years old... That kind of worries me, I don't think I will drill any holes like they did.
Old 11-06-12, 03:30 AM
chandler's Avatar
It's LVL. My eyes aren't as good as they used to be.
Old 11-06-12, 06:06 PM
CasualJoe's Avatar
You're right, Chandler. I never would have thought that after studying the first picture.
