More generator related questions.
Old 12-09-12, 06:13 PM
Good info on the L-5-30 receptacle NOT being GFCI protected.
If it is a problem, how do I separate the ground from the metal boxes I am using. I don't have the inlet yet, but it may bond itself to the box.
No need to separate the equipment from from the metal box, in fact you WANT the metal boxes to be grounded. The ONLY possible problem would come from the boiler transfer switch and I don't think you will have a problem there either. Just don't use the generator-mounted GFCI receptacle for anything that is remotely connected to the house wiring.
Old 12-09-12, 06:16 PM
The plan is to run one cable from the generator into my house. That would be the l5-30 with the gang box. Then everything else will plug into that. Since I don't have the l5-30 plug yet, I plugged into the gfci with a couple things to break the generator in.
My assumption is that the l5-30 isn't protected by the gfci because the max ouput of the gen is 23.3 amps. That would be above the receptacle's rating. There also could be some other standards at play here that prevent them form connecting a 30 amp receptacle to a 20 amp even though it will never carry 30 amps.
  #83
Old 12-09-12, 06:19 PM
Ahhh! Good point, Furd. I don't even have to worry about the GFCI being a problem because I don't plan on connecting it to my house wiring. If I did connect the boiler to GFCI and there was a problem, it would just trip the GFCI, right?
  #84
Old 12-09-12, 06:25 PM
lawrosa's Avatar
Super Moderator
They have this...
Gentran Corporation: Generator Transfer switches for home & business
But in all honesy what I would do if it were myself, and may be cheaper, would be to simply remove the bond at the gen. Then replace the gfi with a regular outlet.
Run your gang box off the l5..... ( Gang box should have GFI. )
Then run the 120v duplex to your furnace switch.
This switch, but not sure what you have.
TF201W Easy/Tran | Product Details | Reliance Controls Corporation
Done....
But thats just me
I posted above but see you will only use the L5. OK did you check the L5 to see if bonded.
Possibly you can scan the schematic and post.... Very interested in seeing it.
"Go Green bay!!!!"
  #85
Old 12-09-12, 06:42 PM
Mike, that seems way more complicated and expensive than what I have already done.
The l5 is bonded.
Look in that manual you posted. The schematic for the YG2800 is what I have.
  #86
Old 12-09-12, 07:01 PM
lawrosa's Avatar
Super Moderator
Sorry to be ignorant. What are you using for the furnace switch?
Easiest IMO would be to just put an outlet for the furnace. Make a wip and plug it in. When power goes out unplug it from that outlet and plug it into the Gen....
Then no worry on bonding/neutral switching....
Done.
  #87
Old 12-09-12, 07:04 PM
Too bad you live on the other side of the country as I have an L5-30 plug (and receptacle) that I will probably never use.
You can easily check if the L5-30 is connected from the GFCI, simply run the gennie and check the voltage at the L5 and then trip the GFCI (push the test button) and see if you still have power at the L5. If yes, then it does NOT come through the GFCI. If no power then it does come through the GFCI.
When are you going to check it out on gaseous fuel?
  #88
Old 12-09-12, 07:23 PM
lawrosa's Avatar
Super Moderator
Doh !!!! I just bought these today....Uggg. Cost me $41 bucks. If droo dont need them, I will trade you a L14-20 gen female and L14-20 male????
Soon to have also a L14 30 female and L14 30 inlet Male.
Worth a shot....LOL
  #89
Old 12-09-12, 09:19 PM
Always check ebay for the locking plugs, receptacles and connectors. I think I paid around $9 to $14 each vs. $20 to $30 each at the big box stores.
  #90
Old 12-10-12, 02:15 AM
I'll check out the gen on gaseous fuel once I get my hose. So probably this weekend. I need to do some major repiping for natural gas. Not sure when I will do that.
I have an l5-30 plug on order from Amazon for like $12.
I am using a DPDT toggle switch that I mounted in a double gang box. It is on-off-on. I have a single gang mounted next to it where I will have the inlet for the generator.
  #91
Old 12-11-12, 03:30 PM
Here is the setup at my boiler: IMG_0051 | Flickr - Photo Sharing!
Looks like my l5-30 plug will take awhile to get here. Not sure where my gas hose is at the moment either.
  #92
Old 12-11-12, 04:33 PM
lawrosa's Avatar
Super Moderator
They sell them at the home stores...... I just bought one to mod my gen.
  #93
Old 12-11-12, 04:49 PM
Sold out at the two by me.
  #94
Old 12-11-12, 05:43 PM
Drooplug -
I got what you need if you work in the city..
  #95
Old 12-13-12, 11:46 AM
lawrosa's Avatar
Super Moderator
Interesting.
Oh , consumer info at the bottom of page 1 gave me a chuckle.
http://www.gen-tran.com/assets/pdfs/...Bulletin20.pdf
  #96
Old 12-15-12, 08:29 AM
Success! I got my hose and l5-30 plug this week. I got the generator up and running on propane. My boiler ran without an issue and so did the refrigerator. Thanks for all of the insight.
  #97
Old 12-15-12, 09:09 AM
Post some pics. Just curious. Did you end up putting the regulator on the tank OR did you mount it on the frame. I'm not a fan of the regulator on the frame/case. I see the benefits of it....just hate the *hacking of the chassis* - keeping things OEM...
  #98
Old 12-15-12, 09:52 AM
IMG_0056 | Flickr - Photo Sharing!
IMG_0055 | Flickr - Photo Sharing!
I bought the generator with the kit already installed by the dealer. They mounted it to the frame. It's just a couple bolts. I think it looks just fine. I don't see how would could keep it separate given the need to have two hoses attached to the gen. If I recall correctly, you need to keep those hoses as short as possible as well.
  #99
Old 12-16-12, 07:26 AM
Don't forget to break the engine on good 'ole fashion gasoline though
  #100
Old 12-16-12, 09:22 AM
I'm way ahead of you .
