Safety switch question
Old 11-05-12, 06:10 PM
I just discovered a 30 amp fused safety switch in my basement that has 2 12 gauge circuits powered thru this switch. Am I correct in thinking this is unsafe, and would replacing the 30 amp fuse with a 20 amp make it safe
Jack
Old 11-05-12, 06:20 PM
ray2047's Avatar
What does the switch power? What size breaker supplies the switch? If it is only serving as a disconnect for a 20 amp feed it may be okay.
Old 11-05-12, 06:29 PM
The circuits are for overhead lighting and receptacles in an area that was used as a woodworking area by a prior tenant
The feed to the switch is 20 amp.
Jack
Old 11-05-12, 06:40 PM
CasualJoe's Avatar
And......how many amps is the breaker rated for that feeds this area?
Old 11-06-12, 04:43 AM
chandler's Avatar
You won't have a problem as long as the initial breaker is 20 amps. Unless you plan on eliminating the switch, leave the 30 amp fuse in there. Otherwise it will cause nuisance blow outs should the draw approach limits. You are fully protected at the panel. I would eliminate the fused switch to create less confusion and replace it with either a disconnect or, if the switch is not needed, a junction box.
