Ikea Desklamp Adapter broken - go straight to wall?
Old 11-09-12, 06:25 PM
Hey guys,
Quick question to run by you - I have a pair of older Ikea desk lamps where the cord plugs into a separate wall-wart AC adapter. Both the adapters, from getting so hot, cracked and pretty much have fallen apart.
I was wondering if I could just splice a 2-prong or 3-prong plug to the end of the cord and bypass the AC adapter all together.
The specs of the adapter are:
INPUT: 120VAC, 60hz, 0.203A
OUTPUT: 12VAC 1670mA 20VA
I know most wall receptacles are 120vac/60hz/15-20amps
So would I be able to bypass the adapter and plug the lamp in directly to the wall? It's a small-bulb halogen lamp and has an on/off switch. I know for a fact there are other halogen lamps out there with bigger lamps that don't use AC adapters. Also, if I were able to do this, would I just splice a standard 2-prong plug in?
TIA!
Old 11-09-12, 06:35 PM
NO.....YOU CAN NOT USE THOSE LIGHTS WITHOUT A/C ADAPTERS
Old 11-09-12, 06:37 PM
Thanks! So I guess I'll just look for another adapter with the same specs, and may end up having just to splice in?
Old 11-09-12, 06:52 PM
Yes......many around. Do a search. I've left you a link to a perfect adapter, very affordable and with screw terminals for connections.
MGT1220: MG ELECTRONICS: Power Supplies & Wall Adapters
Old 11-09-12, 08:06 PM
Nashkat1's Avatar
Radio Shack should have a transformer with the same output specs, including polarity, which you didn't mention. They should also be able to fit the lead with a plug that will match the inlet on your lamp.
Old 11-10-12, 08:55 AM
What would possibly make you think you can just connect a 12-volt lamp to 120 volts??
