Adding Switches Help
Hello,
In my basement I have 4 lights and to control these lights I have 2 switches.
What I am looking to do is add more switches at the top of my stairs to control lights I don't really need to turn on all the time.
When I opened up my light switch at the top of my stairs I have the following:
2 black wires tied together
2 white wires tied together
1 black 1 white 1 red tied to my switch.
Is it possible to add additional switches?
Thank you for your help
Assuming this is cable not conduit tell us how many 2-conductor cables (black, white, bare) and hoe many 3-conductor cables (black, red, white, bare) are at each switch box. Tell us the wiring at the other switch box and at each light.
Hi and thank you.
It is a 3 way sorry about that.
Each of the 4 lights have 2 black and 2 white wires
And 1 light connected ( a black and a white ) to these 2 wires
Both light switches have a black, red, and white connected.
The switch upstairs has what I explained
It is a 3 way
The bottom switch has a black a white and a red..
Power is at the top switch.
If you tell us the number of cables coming into each box, the number of wires in each of those cables, and the way each of those wires is connected, it will help us understand your present system better, and thereby help us to provide more helpful advice. Remember that the three terminals on a 3-way switch are one that is the common, or point, terminal. It is usually distinguished by having a black screw. The other two terminals are the traveler terminals, and they are usually distinguished by having bright brass screws. We need to know what wire from what cable is connect to the point screw and what two wires from what cable are connected to the two traveler screws on each switch.
What we are looking for is a complete circuit - both hot and neutral in a single cable - from the panel. That may be in the switch at the top of the stairs. Once we - including you - figure that out, and we determine which lights you wish to separate out and control from new switches, we can advise you on the best way to do that.
