Does an outdoor receptacle require GFCI?
Old 11-12-12, 04:03 PM
I'm preparing to add a 220v/50a receptacle outside. This will require installing an appropriate 50a breaker in the main service panel. My question is -- Does NEC specify/require GFCI style for this circuit?
Old 11-12-12, 04:23 PM
ray2047's Avatar
What will the receptacle power?
Tech Note: It is 240v volts not 220 volts if this is residential single phase.
Old 11-12-12, 04:39 PM
Yeah, that 220/240 gets interchanged so much I sometimes oops. The receptacle will power a 240v/48a stick welder (single-phase). Running UF-B 6/2.
Old 11-12-12, 04:54 PM
pcboss's Avatar
A 240 volt receptacle outside will not require GFI protection.
Old 11-12-12, 06:37 PM
Appreciate the replies!
That's what I was hoping to hear. Every $35 saved is a plus.
Old 11-12-12, 07:18 PM
pcboss's Avatar
A two pole GFI breaker would have been way more than $35.
Old 11-12-12, 07:46 PM
Ouch, you're spot on. A quick check shows a nearly $80 difference. That makes it even better news.
