timer switch
Received 0 Votes
timer switch
I want to replace a standard single pole switch with a timer switch. The current single pole switch has a black wire and a white wire connected to it. The new timer switch has a black wire, white wire and a red wire. What do I do with the red wire ?
That new timer requires a dedicated neutral which you don't have.
Black - 120v hot
Red - switched 120 v
White - neutral
Do you only have the white and black wire in that switch box ?
Black - 120v hot
White - neutral
You don't have a neutral in the box. Verify that. If you have a bundle of white wires capped and stuffed in the back of the box, then you have access to a neutral. Doubtful that will happen. The white wires on the switches are technically "black" switch loops, so envision them as black, not white.
there are three other switches in the same box. Can I splice the white into one of them?
Black - 120v hot
White - neutral
White - neutral
