Electrical Panel Screws ?
Old 11-17-12, 06:35 PM
I have a Murray Panel installed around 1984 - when I purchased the home.
Turns out the contractor eons ago lost them and just used -whatever- screw to hold the panel. Long gone by now.
I can't seem to find the right thread/screw for this panel.
Anybody happen to know what screw/thread pitch it uses or am I going crazy
Old 11-17-12, 08:00 PM
chandler's Avatar
Panel screws are sold in packages at box stores. They have a rather course thread, I believe 10-24 and above all, they have a blunt end to help eliminating wire punctures.
Old 11-17-12, 08:26 PM
XSleeper's Avatar
Just to add to Larry's comment, big box stores have those packages on a hook in the electrical section along with the electrical panels.
Old 11-18-12, 07:46 AM
CasualJoe's Avatar
Every manufacturer uses slightly different screws. The exact screw is not critical as long as the cover is securely attached to the box.
Old 11-18-12, 08:39 AM
Tolyn Ironhand's Avatar
Many times the panel screws will have a very large head. If you can not find a screw that works, I have used toggle bolt screws that are 3/16" and cut them off to the right length. They have a large head to help hold the cover on.
Old 11-18-12, 10:24 AM
Amazon has everything!
Amazon.com: Siemens ECTS2 Cover Screws for Siemens or Murray Load Centers: Home Improvement
I do know that the 80's era Murray panels have a coarser thread than current. Will still work but harder to get the screws started.
Old 11-18-12, 10:46 AM
Even better! Thanks Astuff
Old 11-18-12, 06:23 PM
CasualJoe's Avatar
OR.....Cheaper at Home Depot......still might have to order them though
Trim Screws for Siemens and Murray Load Centers (6-Pack)-ECTS2 at The Home Depot
Old 11-18-12, 06:39 PM
Justin Smith's Avatar
Square D panel screws work in Murray panels as well.
