bonded!
Old 11-20-12, 02:33 PM
bonded!
I finally got the panel bonded in both spots to be double sure its secure(that green screw did not reach back of box when filly screwed in to neutral bar had to use regular one with spacer).Got neutral bar bonded to panel via#6 copper wire.
Also grounded at pipe and used anti corrosion on the aluminum connection(not the copper pipe).Name:  IMAG0156.jpg
Size:  31.3 KBName:  IMAG0155.jpg
Old 11-20-12, 07:32 PM
Tolyn Ironhand's Avatar
FYI - most locations around here require the water pipe bond the go around the water meter with a clamp on both sides. This wire should be continuous (In case you have a meter inside)
Also, have you installed a ground rod? Might as well do that too.
I hope your screw you used for the lug on the case of the panel is not a self tapping/sheet metal screw but one that has a 32 thread. (IE: 10-32)
Old 11-20-12, 07:56 PM
Nashkat1's Avatar
What kind of screw did you use to make the bond?
Time warp again!
Old 11-20-12, 08:02 PM
it connects- metal- to outside grounded box which is grounded [ATTACH=CONFIG]5754[/ATTACH]
Old 11-20-12, 08:22 PM
are you asking on the one at top of neutral bar?-is 10/32
Old 11-20-12, 08:35 PM
Nashkat1's Avatar
IDK. Which one are you talking about here?
Old 11-20-12, 09:18 PM
Im answering 2 different posts..-older post-.just showed ground to outside .and has aluminum to copper pipe.//
...recent post -the one in the neutral bar at top middle area--this is a before/after pic of the screw .
-isnt it supposed to be 10/32 on the screw size for bonding?
Size:  30.3 KBName:  IMAG0156.jpg
Old 11-21-12, 08:50 AM
Here is a updated pic[ATTACH=CONFIG]5763[/ATTACH][ATTACH=CONFIG]5765[/ATTACH]
Old 11-21-12, 11:22 AM
Will a zinc clamp work ok in place of the one in early pic? - (AL to Cop)
Old 11-22-12, 04:33 AM
The green screw is much better!
