How can I secure flex/BX from the *inside* of a box
Old 11-25-12, 02:32 AM
P
If I can manage to get the knockout dealt with from the *inside* of the box, and then fish a new run to it , whether it be flex or BX - is there any advice you can offer on how to SECURE the cable to the box . All the fittings that are meant to secure it are generally from the outside in. Cutting the wall open is not a option as no access from the back *exterior* and the front is tiled.
Old 11-25-12, 04:06 AM
chandler's Avatar
Received 5 Votes on 5 Posts
If you can manage to get the knockout and the cable run, you can attach the AC fitting to the end of the cable before you start fishing it and secure it with the provided nut on the inside of the box as normal. Be sure to use the non shorting bushing that comes with the fitting. There are no fittings to my knowledge that you can use inside a box. There is no room for it and it will cause a hazard to have the metal sticking into the box, reducing the space you need for switches, etc.
Old 11-25-12, 04:34 AM
D
You can also remove the existing box and reinstall with an old work box. That will allow you to attach the cable with the box outside the wall and then install the box. If you have several cables entering different sides, this will be difficult if not impossible.
Old 11-25-12, 07:14 AM
P
Chandler -
That was Genius. Just prefit the end and fish it with it.
It never even crossed my mind..
Old 11-25-12, 07:45 AM
A
Received 39 Votes on 35 Posts
If it is a 1/2" knock-out then fishing cable with the fitting on it is the way to go. If it has two small knock-outs on each end of the box with a slot in it then it is meant to have a double internal clamp. Big box stores don't sell them individually but have them for some of the metal boxes.
[ATTACH=CONFIG]5941[/ATTACH]
TP900 - MC BX CLMP WITH SCREW REPLAC PART | Westway Electric Supply
Old 11-25-12, 08:29 AM
P
I've always used the knock out fittings.
Riddle me this....those clamps *which I'm familiar with*, are those rated for both MC and AC cable. And or why 1 and not the other..
Old 11-25-12, 08:40 AM
Received 1,051 Votes on 975 Posts
They are rated for both Armour clad and Metal clad cables.
Old 11-25-12, 08:48 AM
Tolyn Ironhand's Avatar
Received 205 Votes on 182 Posts
The fittings that are rated for MC cable, but not AC cable, is because they are not rated for grounding. With AC cable the jacket, in conjunction with the bonding strip, is your grounding path and the fitting is not rated for that. Standard MC cable has a separate grounding conductor.
The Exception is MCAP which also uses the jacket as the grounding path. With MCAP you need to make sure that you use approved fittings. Long story short, any fitting that is approved for AC is also approved for MCAP. http://www.southwire.com/documents/L...olidMCAP_2.pdf
When fishing the cable/fitting use one that uses a locknut, and remember to remove the locknut before fishing the cable in.
Old 11-25-12, 11:08 AM
P
Oh. So close yet so far.
All the bottom holes on this 4" Box are populate. Managed to get a knockout on the top. Got my fish through....but between the deep box fairly flush to the wall and the knockout being on top, it just won't budge that last inch where I need the cable with the fitting to HUMP over to the top....
Before I start going to town, plan to take a breather - then drillout a knockout from the back, wedge it out....and then reattemp this again from the back.
In an ideal world, I would have just fished it right up, coming from the bottom to a bottom knockout
Old 11-25-12, 11:14 AM
P
For those that have more experience hands....bearing the above statement, do you think a romex fitting is a slightly lesser bulkier....and might pull better if the cable is coming from below but I'm pulling to a knockout ONTOP of the Box.
Romex has been allowed for the last couple years in NYC but been slinging BX all my life and have only used Romex between a LV transformer to undercabinet electrical stuff
Old 11-25-12, 11:51 AM
chandler's Avatar
As long as romex (12-2 wg nm for instance) is approved for use in your municipality, then, yes, I would pull it rather than AC. Here, again, you may want to attach the strain relief to the romex, about a foot or more down the cable, then fish the cable in, and pull it until the fitting sits in the hole, then slap on the nut to hold it.
Old 11-25-12, 11:54 AM
P
Yeah. I think I might have better success with Romex as it can Kink More.
I've got most of the cable in the box. It's just that last 2 " with the fitting that I just can get over to the top of the box
Old 11-25-12, 12:33 PM
chandler's Avatar
You may could have used a 90 degree AC fitting and come through a hole in the back of the box. Just sayin..............
Old 11-25-12, 01:14 PM
P
Ha. The only reason I went for the top knockout *knowing I might get jammed up* like I am right now was that it was a clear shot to work with.
The fill of the box - in front of the back center has 5 or 6 pairs of 12 gauge pigtailed into one web I don't really work through
I've left my existing drag and plan to regroup for another day.
The wifey want's her countertop back
Old 11-25-12, 03:27 PM
IF you can get the fitting close to the KO, you can sometimes jamb a narrow screwdriver between the drywall and the box and use that to pry the fitting into the hole. The device plate will cover any damage you may cause.
Old 11-25-12, 04:43 PM
chandler's Avatar
Now I am getting concerned with your box's fill. Is this a device box or a junction box? You may have it overloaded with cables to begin with. What size is the box. LxWxH?
Old 11-25-12, 05:14 PM
P
Device Box. She's all buttoned back up but a wild guess would be 4 1/2 4 1/2 x 3" Deep box with a Mud Ring so make that 3 1/4"ish Depth. Just a single receptacle in there. 5 Pair 12 gauge for sure. The goal of this was to add a second recept - on a different circuit.
