Wiring with push on connectors
Old 11-25-12, 09:46 PM
I put two T12 4 footer tube fluorescent fixtures up and was about to use some Wago Wall Nuts push in connectors. Box says they're good for 12 - 16 AWG stranded and 12- 18 AWG solid wires. The solid wires go right in and stay in. The stranded come right back out.
Any one use these, or any tricks to gettin it to work?
Old 11-25-12, 09:55 PM
I was never a big fan of those push in block connectors.
Maybe your stranded wiring is smaller then it calls for ?
Old 11-26-12, 03:18 AM
chandler's Avatar
Push block connectors are great for solid wire, but less than stellar for stranded. I would opt for Bcaps for the stranded wire, or if you have a combination of stranded and solid, Bcaps all the way.
Old 11-26-12, 07:11 AM
You can still buy T12 fixtures?
Old 11-26-12, 08:18 AM
Justin Smith's Avatar
I found them to work better if you tin the conductors first. I'm also going to recommend using wirenuts for the heavier loads, like receptacles.
Old 11-26-12, 04:58 PM
chandler's Avatar
Guy, yeah, I had to buy 8 of them in 8' lengths for an auto parts warehouse. Old geezer didn't like the newer fluorescents. Customer is always right......well he got what he wanted, but may realize there is greener grass.
Old 11-26-12, 08:42 PM
Just about the time that guy will need replacement tubes for his dinosaur fixtures.....the tubes will also be extinct. 8' T-12's are already out of production.
Old 11-27-12, 03:10 AM
chandler's Avatar
I told him that......He just doesn't trust newer technology. I explained I could get brighter light for his shelving with 4' T5's than he would get with the 8' T12's, but Noooo. That's OK, when he sells the business I'll have another job when the new owner looks at things.
