SER cable into an exterior wall-mounted spa disconnect panel?
SER cable into an exterior surface-mounted spa disconnect panel?
I'd like to install a packaged, surface-mount spa GFCI disconnect panel on the exterior of my recently-built stucco home.
The 40A circuit the builder installed for me is SER 6-6-6-6 down the interior of the wall to a 4" non-metallic box low in the wall, open to the exterior, currently capped with wire-nuts and covered with a weatherproof plate.
My thought was to pull the SER up to a new opening about 5' high, and bring it through the stucco and the rear knock-out of the surface-mounted disconnect panel. My question is, is there an NEC 2008-compliant way to secure and protect the SER, and maintain the weather-resistance of the box?
If not, any suggestions as to an alternative? The panel I'm looking at has conduit hub knock-outs on the top and bottom as well as the knock-out in the rear.
Thanks,
John
Thanks,
John
You should be fine to use the knockout on the back of the disconnect. Add a SER clamp to the cable and secure with a locknut.
Add an upside down U of caulk above the cable.
