#6AWG neutral conductor will not fit on bar
Old 12-01-12, 03:59 PM
Bernard_01's Avatar
greetings again from NH,
I installed a new electric range and the #6awg neutral conductor does not seem to fit into the provided hole in the neutral bar at the panel. Can you pros suggest a couple of options? THANK YOU ALL.
Bob
Old 12-01-12, 04:19 PM
ray2047's Avatar
Received 15 Votes on 13 Posts
You can use a device such as below to use two holes on your neutral bar.
Old 12-01-12, 04:33 PM
Bernard_01's Avatar
so, those two little nubs will fit into 2 existing (empty) holes on the neutral bar?
At the range the neutral screw and the ground screw are bonded together with a copper strap.
My conductors are the black, red, and white. all #6awg. The black and red are both going to the DP 50a breaker. My white goes to this device you showed and connects to the neutral bar correct? So, the neutral bar is in effect acting as my ground also?
thanks.
Old 12-01-12, 04:56 PM
Nashkat1's Avatar
Received 5 Votes on 4 Posts
The neutral and ground should not be bonded together anywhere beyond your main distribution panel, and the wiring for your range should be 4-wire to comply with current code.
Old 12-01-12, 05:07 PM
Bernard_01's Avatar
so, i will change the 3 prong receptacle for a 4 prong receptacle. the new circuit fron the panel will have 4 wires. i will eleiminate the bonding strap on the appliance, and i will run cable with black, red, white and ground conductors. i will install a new appliance cord made for 4 wires. does this sound right? ty.
Old 12-01-12, 05:31 PM
Nashkat1's Avatar
Yes, that sounds right .
Old 12-01-12, 06:04 PM
ray2047's Avatar
Panels can vary. Just be sure it is made to work in your panel and it should.
Old 12-01-12, 08:10 PM
pcboss's Avatar
Received 141 Votes on 125 Posts
Many panels will accept up to a #4 in the bar without an adapter.
