1.485" diameter outlet
Received 0 Votes
I have a Box where it's currently being used as a splice from indoor-outdoor pipework on the outside of my house.
It's a 2 Gang with a blank cover.
I wanted to utilize it as well for a outlet.
I found a 2 gang box cover / that has covers for 1 1/2 *1.485* diameter outlets to be exact.
I quick measure of a 20 or 30 amp Locking Outlet in my stash show's it's about a hair larger than 1/2" in diameter.
Can you guys advise why type/style of Outlets is this cover meant for ?
Cover here - http://www.tnb.com/ps/fulltilt/index.cgi?part=2CCS
Their description indicates it "reduces callbacks". Well, only if you don't forget to get the right receptacles. Anyway, you can't use this cover in an exposed area. You will need a code compliant bubble cover, so you may as well use regular receptacles and a bubble cover.
Received 0 Votes
Chandler -
Interesting Blurb on Exposed Covers - Bubble Cover......
I have also been looking at Locking Recetacles- Flanged with the large Port/ Flip Cover for a Generator Feed. Now, MOST of these are similar to traditional flip covers with the exception of some really $$$$ Marine Grade Ones.
I can see Hubell offers a nice 120/240 50 Amp with a Angled Down unit.
I don't see one similar in a 120/240 30 angled version.
Most *generator kits* seem to just offer one that is flip lid...
I myself have been looking for something that is not $$$ Marine Grade but a but more weather resistant.
Back to your comment....which one do you guys recommend or use when the INLET is exposed and not inside a detached shed, etc.
Received 0 Votes
The OP was re: outlets for the linked outlet cover in the OP.
When you mentioned the water resistent/weather resistent issue, I took it OT as I was indeed looking at boxes for a INLET for a generator as well...
Different applications but for all intents and purposes, in the Exposed Elements.
