Handyman estimate pricing per foot? (I'm the handyman)
So recently I've been doing some handyman work on the side for extra cash. Its turning out actually much better than I thought it would. I've got tons of work.
I'm now trying to streamline some of my processes to make things easier on myself. When I am estimating electrical work, is it reasonable to just charge a per foot price? This price would be high enough to cover most romex 14/2 14/3 12/2 12/3, wire nuts, gang boxes etc....
So if it were say $1.25 per foot for 14/2 work...
is this idea totally ridiculous? Am I setting myself or my customer up for a loss?
Just seems simpler than saying "25ft of 14/2 @ .40 per foot... 1 single gang @ 2.98, a piece of conduit @ 4.00, etc".
Any suggestions? I was thinking of this estimation model for plumbing work too to avoid having to try and itemize in my head how manx 90's, p traps, etc.... plus the cost of glue, etc.
Before this goes any farther you need to check the licensing requirements in order to install electrical work. Many areas require only a licensed professional to install electrical wiring.
First off I should point out that many states/cities require that residential electrical work is either done by the homeowner, or a licensed electrician/electrical contractor. And commercial electrical work done only by licensed electricians/electrical contractors. Also, said electrical with the exception of minor maintenance work, will require a permit(s).
Info from your state found here: Maryland
"General construction contractors don't need a license to work in Maryland. You will need a license to do electrical, plumbing or HVACR contracting, or work on home improvement projects."
To your question, we just count and multiply.
Example:
4 Duplex receptacles @ $30 ea
6 cans @ $50 ea
3 switches @ $25 ea
Total: $495
By figuring by each opening, or device, you come up with a number that will also cover the cost of the cable, straps, and labor to install. Then add other special things like AFCIs, GFCIs, hanging a fan, extra long drive, etc.
Example:
6 cans @ $50 ea
3 switches @ $25 ea
Total: $495
Example:
6 cans @ $50 ea
3 switches @ $25 ea
Total: $495
Example:
6 cans @ $50 ea
3 switches @ $25 ea
Total: $495
