Stranded or Solid to Panel
Received 0 Votes
I've only terminated stranded to a breaker a handful of time and unless it's me, solid does seem to be a more *solid* connection.
I am running wire from transfer switch to the panel.
Any benefits going with stranded over solid for this application ?
Conduit or cable? What size wire? How many wires? What do you need to go around or through between the transfer switch and the panel?
The tricky part with stranded conductors is making sure that all of the strands are intact after stripping the insulation and making sure all of them are inserted and clamped in the lug.
Received 0 Votes
I'm not a fan of tinning the leads of this application. I got to my my EE hat on, but something like strands may be lossened over time under the tin, resistence, etc, etc.
8 Pairs of 12AWG
Another pair of 10AWG for the neutral and Ground
Flex run straight shot about 5-6 feet.
It's on the same plane as the panel....flush with the concrete wall.
8 Pairs of 12AWG
As I said earlier, just make sure that all of the strands are intact after stripping the insulation and make sure all of them are inserted and clamped in the lug. This is one of the few times that I actually bother to re-align the strands before terminating - never with a splice anymore. One point I forgot to make earlier is to make sure the conductor reaches the bottom of the lug and that the insulation comes to within a whisker of the opening. Also follow the torque schedule. (You may already know this, and some of it better than I do, but lots of folks read these posts for information.)
8 Pairs of 12AWG
Yep, sounds like an eight circuit transfer panel with a maximum generator size of 7200 watts. One #10 for a common neutral and the other #10 for the equipment ground. Obviously NOT switching the neutrals.
Received 0 Votes
BTW, just curious....
HOW do you guys organize/label such wires ?
Just the regular A-Z sticker Book ?
I've got to grab the Brady printer from work which should be perfect on the cables.
Received 0 Votes
At the approach I'm coming in, I'm thinking the KO required will most likely be on the bottom - a smigen right off the meter.
I don't have one of the fancy schmancy Greenlee knockout cutters...
That said, the company that made your transfer panel may have designed it so that the various conductors should come in at certain points, and provided KOs there. I would look over the panel and the Funny Papers that came with it to determine the best internal wiring path before making any openings in it.
FWIW, I noticed recently that I can buy pre-bent 90s in several different sizes of EMT at my local Big Orange.
