Tips of block heater cord ground down...
Old 12-06-12, 11:36 AM
Hello.
My block heater plug (the male end) unhooked from the protective cap on my way to work this morning. Must have been dragging along the road as I drove and now the metal prongs have had the tips ground off. Is it still useable or do I need to replace it?
Thanks,
Kristin.
Old 12-06-12, 11:55 AM
Could you post a pic or two so we can see how bad the damage is? http://www.doityourself.com/forum/el...-pictures.html
Old 12-06-12, 12:02 PM
Will do! I'll grab a photo tonight before heading home!
Thanks!
Kristin.
Old 12-12-12, 02:50 PM
Sorry about the delay—here's the shots! What do you think?
k.
https://dl.dropbox.com/u/10550079/cord1.JPG
https://dl.dropbox.com/u/10550079/cord2.JPG
Old 12-12-12, 02:58 PM
Gunguy45's Avatar
Super Moderator
Cut the plug off and use a good quality replacement. Plenty of choices. May have to think outside the box for something to protect it when not in use...but you could just mount a cheap receptacle in the engine bay and plug it in when not used to keep it out of the way?
Old 12-12-12, 05:32 PM
pcboss's Avatar
I too suggest replacement. You don't need to find the cord overheating or your diesel truck on fire.
Old 12-12-12, 07:50 PM
Justin Smith's Avatar
If this was my truck, I'd mount an inlet somewhere in the body or bumper.
Old 12-13-12, 06:16 AM
Thanks all.
Yea, I kinda figured the plug was a write-off, but I just wasn't sure if I need to replace the entire cord or if I could just cut the plug off and attach a new one (which is what I'm hoping). Sounds like this is possible, but what's considered a "good quality replacement"? I know the extension cord I use for hooking it up at night is "block heater" grade (or, at least that's what Home Depot called it), but since I'm just going to look for a replacement plug, is there any rating or other information I can use for finding the replacement?
Re: Protecting it. It actually has a protective cap, etc. which I thought was good enough, but I guess after a few years, it became too loose and finally slipped out. I'll definitely make sure to get a better replacement for that as well!
Thanks again!
Old 12-13-12, 06:37 AM
Halton's Avatar
As stated......replace it with a quality heavy duty plug.....similar to the one below.
You then need to route the cord and fasten it to a convenient location using zip-ties.
Somewhere in the upper portion of the engine bay which will also keep it dry.
Old 12-13-12, 06:38 AM
Thanks! Much appreciated!
Old 12-13-12, 07:56 AM
You want to look for the black and white plugs over the yellow ones as they're more durable and easier to wire.
