Reload this Page >
Outdoor light fixture / box installation with armored cable
Old 12-27-12, 08:23 PM
Hello,
I am trying to install an outdoor light fixture (a floodlight) onto the side of my house which has vinyl siding.
I want to use a mounting kit like this one: Amazon.com: Arlington 8151-1 Vertical Siding Lamp Mounting Kit with Built-in Box for 5/8 Inch Vertical Siding LAP: Home Improvement
My home is wired with armored cable (mechanical ground (bonding strip) - no separate ground wire).
How is this done safely and in compliance with code? Do I have to use a metal box? Can I convert to NM cable at a box inside of the house before the wire passes into this plastic box? All of my interior walls are open, beams exposed. This is in NYC.
Thanks!
Old 12-27-12, 08:49 PM
I don't think you can use NM cable in NYC.
You used to be able to get a similar siding adapter plate with a single gem cutout. This way you could use a metal box but the adapter plate would be plastic so as not to rust.
I'm looking for it now.
Old 12-27-12, 08:51 PM
NM cable was made legal in NYC a few years ago (at least for private homes 3 stories or less).
I did a bit more research --
I believe I would just run the NM from one of my metal boxes with AC cable in it (ground the NM with a grounding clip / screw to that box) out to that plastic box I linked to. Would I have to use NM cable rated for wet locations?
Old 12-27-12, 10:00 PM
ray2047's Avatar
NM-b is not rated for wet locations but for what you want to do you do not need to use cable for a wet location. At the metal box you start from connect the NM-b to the metal box with a 10-32 ground screw. You can use a plastic box on the side of the house.
Old 12-27-12, 10:37 PM
Makes perfect sense. Thank you both for your help.
