Novice wiring question
Installing a chandelier in my bathroom. The chandelier of course has the white and black wires and green ground screw. The junction box has the following wires
Gray
White
Black unstripped with no wire nut
Blue
I assume the gray here is the live, white neutral, and the long unattached black is the ground. What about the blue?
Can I ignore the Blue? Is the ground mandatory? It was obviously not used previously.
Thanks in advance.
Gray
White
Blue
Thanks in advance.
Colors in the NEC are a follows:
Gray or white, with or without stripes, is the neutral (the grounded conductor)
Bare, green, or green with yellow stripes is the ground
Any other color wire is hot. (ungrounded conductor)
To make sure the gray is really a neutral, take a meter and measure voltage between it and an ungrounded conductor. You should get 120 volts. Then measure between the gray and the white, first with the meter set to volts. Then, if you do not get anything, set it to ohms and take another reading. If it is also a neutral you will get close to zero ohms.
The ground should always be used where available. The unattached black could be either an extra wire for another circuit, or just another switch leg for a ceiling fan. Since I can see it appears to be a fan box.
How many switches do you have for this room?
Welcome to the forums!
How was the fixture that you removed connected?
Glad you asked. The black is not a grounding conductor. The path to ground from this box is the box itself and the metal conduit through which the wires were pulled.
Gray should not be live. It is the color designated for neutrals in 277Y/480V systems. If it's spliced to a white wire, as it looks like it is from your picture, and the white wire is a neutral, then it is definitely not a hot wire! Most likely the neutrals were pulled in two slightly colors, or one has become discolored.
How heavy is your new chandelier? That ceiling box may not be rated to hold it. Also, you will need to add an extension to the box, or replace it, to bring the face of it to within 1/8" of the surface of the ceiling.
I suggest you buy a copy of Wiring Simplified. It will help you get a better grasp on how electrical systems work.
ECHO, ECHO, Echo, echo...
You are going to need to use an extension ring on that box to meet code. It is recessed way too much. What is the wiring at the switch Where is the ground? Is this conduit? (Wires look white to me.)
There are strict prohibitions against chandeliers and other fixtures that are suspended in bathrooms within 3' horizontally of a tub and 8' above.
Thanks for all of the info.
The home is new to me and the previous owners removed the light fixture here, so I don't know how it was previously connected. It is a relatively recent rehab (2003) in a "relatively" old (1886) home. It is conduit.
There are three total light switches in the bathroom, this fixture has only one switch (a dimmer).
The dark gray and white are not spliced together.
Looks like I need to invest in a meter. If the dark Gray and white are connected to the light, and the black is an extra fan switch leg, any thoughts on the blue?
Thanks
Thanks
BTW both the white and and dark gray enter from the side of the box and exit thru the top. The black and blue both come from the top of the box.
IMG_2092_zpsab89d568.jpg photo by gbezanis | Photobucket
In your new picture, I see a black white pair in the 1/2" conduit entering from the side. In the 1/2" conduit entering from the top, I see a second black white pair, plus a single black and a single blue.
The single black and blue appear to be larger gauge wire than the black/white pairs. In addition, the smaller blacks are spliced together and the whites appear to be.
Where is the gray wire?
How high is the ceiling above the floor?
OK I got a meter. The switch here is a dimmer light switch with no fan controls.
"C" (which I would call dark gray relative to the absolute black of "D" - no Brown) is definitely live, reading 120
"B" is a neutral and I will call it white - no reading
"A" is also definitely live reading 120 - it is Blue
"D" is no reading.
The height of the ceiling here is 8 feet 7 inches. The chandelier is relatively small, flushmounted, with only one bulb right at the level of the ceiling.
I looked for an extension for the box, but they were much too large, would extend out from the drywall an inch or so - I would need one about 1/2 inch thick.
Can I just connect "C" to black on my fixture, "B" to white, tuck the others up and be done?
Thanks
"D" is no reading.
Thanks
This is the extension you need:
[ATTACH=CONFIG]8078[/ATTACH]
Was your test with the switch on or off? You should test with the switch on and off so you will know which wire is the switch leg (I'm guessing it is wire "c")
(.kcalb ot "A" dna etihw ot "B" tcennoc ot deen lliw uoy taht gnisseug m'I)
You are right, I was calling it a chandelier due to all of the glass!
You are right again about the wires. It is A that is controlled by the switch in question (C is always live). So I will connect A and B to the fixture.
Finally, I would like to take this opportunity to switch out the annoying Lutron dimmer
for a simple on/off decora style switch. What amp specification is recommended here?
Glad you got it, and thanks for the feedback. As far as the switch goes, that controls a single-lamp fixture. The cheapest decora switch in the store will safely do what you want.
