Load Center
Old 01-13-13, 07:01 AM
Load Center
Can GE THQP 1/2" breakers be used in a Siemens load center?
Old 01-13-13, 07:16 AM
pcboss's Avatar
Only if listed for use in that panel. The label will state the acceptable breakers.
Old 01-13-13, 09:23 AM
CasualJoe's Avatar
They will not physically fit the Siemens bus and they are not U.L. Listed for use in anything except some GE loadcenters, not all.
Old 01-14-13, 09:25 AM
Siemans has a series of space saver breakers. Should be easy to locate some. As stated, the THQP won't fit anything except a certain number of GE panels. Siemans makes a series that has two single pole breakers in a single pole space and two double poles in a 2" space and combinations of those. Of course like anyone elses panel you are limited by the design of the panel. Not all panels accept space saver breakers and those that do are usually limited to a few circuits in the panel....
Old 01-14-13, 11:23 AM
Nashkat1's Avatar
Which Siemens panel do you have?
