Reload this Page >
Grounded outlet required for switch between extension cable and string lights?
Old 01-13-13, 07:31 PM
Apologies if this has already been answered - I found helpful information in previous questions but am not knowledgeable enough about electricity to tell whether we are safe or not. All advice gratefully received.
I have a set of string lights in the baby's room. The light cable is two-prong and comes with an extension cable, also two-prong.
I want to add a switch between the light cable and the extension cable so I can switch on the lights without kneeling down to reach the outlet. I bought a GE polarized handy switch (two prong), thinking this would work. But on the packet is says I need to plug the switch into a grounded outlet.
Can I safely use the switch (between the light cable and extension cable) as intended, or must it be plugged into the wall?
Thanks so much
Kellie
Old 01-13-13, 07:35 PM
Is this some kind of inline control switch ?
Like what's in the picture ?
Old 01-13-13, 08:01 PM
Yeah - that's it. The one I've got is almost identical. Thanks for responding!
Old 01-13-13, 08:07 PM
It's an all plastic device that does not require a ground.
Old 01-13-13, 08:50 PM
Great - thanks so much. I guess the manufacturer's advice to plug into a grounded outlet is not strictly necessary?
Old 01-13-13, 08:54 PM
Justin Smith's Avatar
I wouldn't worry about it.
Old 01-13-13, 10:30 PM
ray2047's Avatar
Well if it doesn't have a ground pin then you really wouldn't be plugging it into a ground even if there was one. What should have been written was to plug it into a polarized receptacle. Just another example of instructions written by the technically challenged.
