Reload this Page >
Number of wires allowed thru a 1-1/2" hole drilled in a joist
Old 01-15-13, 06:04 PM
Started worrying about this a little late, but how many wires are allowed thru a 1-1/2" hole drilled in the floor joists. Attached are pic's of what I have done so far.
I appreciate any guidance and comments.
Dano
Size:  38.5 KBName:  P1030818-qpr.jpg
Size:  36.4 KBName:  P1030819-qpr.jpg
Size:  38.4 KBName:  P1030820-qpr.jpg
Old 01-15-13, 06:28 PM
The wires should fit comfortably and not be jammed in.
The only code infraction that could be called in to play here is bundling.
Personally I think you are fine.
A little blurp on bundling.
Copper.org: Copper In Your Home: Home Planning Series - House Wiring “Bundles” Could Be a Fire Hazard
Old 01-15-13, 06:38 PM
Tolyn Ironhand's Avatar
Short answer is as many that will fit. However, when you get to the cables bundled more that 24", and there is more than 3 current carrying conductors, you have to start derateing the conductors. Good news is that if there is no more than 9 current carrying conductors, and it is all NM-b you don't have to worry because the adjustment factor is only 70%.
#12 = 30 amps @ 70% = 21amps
#14 = 25 amps @ 70% = 17.5 amps
I would also agree with PJmax as they are not tightly bundled. Your inspector would have the final say though.
Old 01-15-13, 06:50 PM
Thanks guys I really appreciate the fast response.
