Quick Help: LED Strips wiring with 2 way switch
Old 01-18-13, 06:30 PM
W
I was wondering if someone could offer some help
I have 8 led strips 12 volt and a 2 speed rotary switch. Its a 120 volt switch, but it works with the led strips fine. What I have wired right now, the 1 position turns on 4 of the LED strips. For the 2 position, I wanted to have all the leds turn on. However, when I wire it up where the 2 is wired into all 8, and the 1 is wired into just 4. All of them come on at each position. Is it possible to wire, the way I wanted?
Old 01-18-13, 06:37 PM
Received 2,801 Votes on 2,536 Posts
A three way switch would be more ideal.
Position 1 - four lights
Position 2 -other four lights
position 3 - all eight
position 4- all off.
If you had your heart set on using THAT switch. Then you would need to use diodes to isolate the sets of four. The only caveat is that you would lose .7 volts.....they would be a little dimmer.
Old 01-18-13, 06:44 PM
W
I figured, a 3 way switch might be easier.
As far as wiring goes
I know I would need to separate the 4 sets for position 1/2, which I have done
Won't I run into the same issue that when I wire in position 3 for all on, then at position 1/2 it will still turn all of them on? Meaning the hots will jump. If that makes sense
Old 01-18-13, 06:55 PM
Connect four LED's to position 1
Connect the other four to position 2
position 3 = postion 1 and 2 together.
Old 01-18-13, 07:11 PM
W
I guess, Ill just have to buy it and see,
Its got 4 solder tabs, like the 2 way one which has 3 tabs
If I solder Position 1/2 to position 3, then all the hot wires are touching again and at position 1 or 2 all 8 would turn on. Is that typical of a 3 speed switch?
Old 01-18-13, 07:27 PM
Ok.......so then you are using a switch that doesn't combine two postions internally.
Its:
position one- terminal one
position two - terminal two
position three -terminal three
common - terminal four.
This type of switch wont do what you want.
You want the type of switch which is a three wire four position one.
Where in position three it combines terminal one and two internally and the third wire is the common.
Old 01-18-13, 08:07 PM
W
ok thanks, Ill take a look tomorrow and see if I can find one.
I am dealing with a very tight tolerance to put this switch in, the one I currently have the 2 speed one fits perfectly. If I cannot locate the right size switch, I will try the diode approach, just need to figure out what kind to get
